Camry stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2005, 10:41 AM   #1 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Camry stalling
It's been doing this for a few weeks, somewhat randomly. It only happens when I'm stopped at a light and when it's cold out. When I start the car after it stalls, it takes longer than normal to get the engine running again. Any ideas on why this is happening? I think my battery may be shitting the bed soon so maybe that's why? Or is it the batt/alt/starter combo? Could it be the fact that I've never changed my spark plugs since I got the car (35k miles ago)?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-31-2005, 10:56 AM   #2 (permalink)
View EngineerBoo's Photo Gallery
We need more information! (Engine/AT?)
But you always want to start with the simple stuff and work towards the harder stuff. It sounds like the timing is dropping too low when stopped....a bad batch of gas can do this....or dirty gas filter or dirty air filter....simple stuff!
I'm amazed at how long people go without changing their gas filter....it's pretty important with today's electronically controlled engines. (And never EVER get gas at a convenience store! Always get gas at a GAS STATION....Exxon, Texaco, etc.)
Rick
EngineerBoo is offline   Reply With Quote
Old 01-31-2005, 11:01 AM   #3 (permalink)
Oops, missed the vehicle info
Ooops, I didn't notice the vehicle info on your post.
Okay, it's an AT....again, if you haven't changed the air filter/fuel filter in a while (should be done once a year) I'd do that, first.
Battery? That's the last thing...keep it simple! Spark plugs? Hmmmm....miles are low but, again, I wouldn't go more than 3 years without changing. (Or, at least, popping them out and inspecting them.)
I've even seen altitude change affect the timing, which is set electronincally. To reset the timing, you disconnect the battery, let it set for at least 20 seconds, and reconnect. This wipes out the saved timing data in the memory module and it resets itself, based on how the engine runs. (But put some high-octane gas and fuel injector cleaner and see if that helps, first.)
Good luck!
Rick
Old 01-31-2005, 11:58 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
well what you want to do is solve teh stalling, not the restarting of the motor, cranking after the engiens just been on tends to take a tad longer then usual, with no auto choke and fuel already being in the cylinders flooding n stuch but yeah, fix hte stalling first :P
is the engine at working temp? i dunno cant help you with this one, try asking a local workshop, they wont charge for that ^^
terrastrife is offline   Reply With Quote
Old 01-31-2005, 02:53 PM   #5 (permalink)
Stealth's Avatar
Maybe its the fuel filter like Boo said, I haven't replaced that. I got spark plugs since they're cheap anyway so I figured it can't hurt to do. I guess if that doesn't solve it, I'll try the fuel filter. The air filter I did about a month ago so that should be fine.
Old 01-31-2005, 07:47 PM   #6 (permalink)
Stealth's Avatar
lil' bit of bump action
Old 02-01-2005, 08:23 AM   #7 (permalink)
View macarlin1's Photo Gallery
Had the same problem
My 95 4 cyl wagon was doing the same thing. I actually got on here to respond to an old post about fixing it.
The car would stall once it WARMED up... at a light or just when taking foot off gas to make a turn. I had the fuel & air filters changed and a tune up but it still kept doing it and my mechanic wasn't sure what was going on.
Somebody here suggested the Engine Coollant Sensor was bad.
Went to AUTOZONE and picked one up for $29. Took about 10 minutes to put it in.
I think that did it. No more stalls. Good luck.
macarlin1 is offline   Reply With Quote
