Rear Disc Brake Conversion problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2005, 10:07 PM   #1 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Unhappy Rear Disc Brake Conversion problem...
I have a 99 I4, with rear drums and am currently going for the rear disc conversion. I already have new rotors and pads but need to know if I can reuse the drum's mechanical parts( of course not the shoes). Or will I need to replace everything? Please help!!
Oh, I have already tried search but couldn't find anything...
Last edited by camry-4-ever; 01-31-2005 at 10:10 PM. Reason: Already did extensive search...
camry-4-ever is offline   Reply With Quote
Old 01-31-2005, 10:13 PM   #2 (permalink)
View anuthaCamry's Photo Gallery
are you kidding? disk brakes use a large piston (at least one) to squeeze a rotor, the piston is located inside a caliper and the caliper is held to the knuckle by something....
More importantly, the proportioning valve is not the same.... and the abs system uses a load senser in addition to a pv.
anuthaCamry is offline   Reply With Quote
Old 01-31-2005, 10:15 PM   #3 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
Drum to disk conversion - DONE
Goodridge Brake Lines #21064
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 01-31-2005, 10:24 PM   #4 (permalink)
Thank you very much Bull!
