tranny flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2005, 03:05 AM   #1 (permalink)
View tavalon's Photo Gallery
tranny flush
i got a 98 camry v6 & i want to flush my tranny. what are the procedures?? and also do i have to drop the pan and buy a new filter????
tavalon is offline   Reply With Quote
Old 02-01-2005, 03:28 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
2000 Camry Auto trans fluid
I suggest that you drop the pan and clean it.
You can either clean or replace the filter, its up to you.
Make sure you replace the tranny pan gasket, if you drop the pan.
"Skoolin' the unlearned!"
Old 02-01-2005, 03:33 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Great! USE HIGH QUALITY SYNTHETIC FLUID
what are the procedures???
88LE linked.
Might as well change the differential fluid too!!!
You'll need a 10mm Allen wrench. The Automatic Transaxle's differential both use DEXRON III or compatible fluid.
Raise vehicle & support on jacks.
Find the differential drain plug. Place the drain pan underneath the plug, remove it with an Allen wrench and drain the fluid. When the differential fluid has drained, reinstall the plug securly.
Add new fluid to the differential until it just begins to run out of the filler hole.
*Caution* Do not overfill. The Automatic transaxle and the differential are separate units.
Lower vehicle
AIM/Yahoo Toysrme257th
Now with Turbo!
