^ they replaced plugs and wires.
If it's still shaking at idle, but the performance is better than the last post, have them clean out the idle air control valve.
Also let them check the ignition timing. That will let you know if the distributor has somehow been set incorrectly, or if they aligned the cams/crank incorrectly (which isn't exactly hard to do... even for a mechanic)
AIM/Yahoo Toysrme257th
Now with Turbo!
