Electronic AC/Heater Controls - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2005, 02:05 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Is there a difference between the Gen 2 and 2.5 'electronic pushbutton' AC/Heater controls? Apart from looks.
Mine is playing up (slider is a bit dodgy and the 3 of the Fan speed settings don't work), and i've located one from Gen 2.5. Looks alot new (black, rounded buttons) and i just need to know if it can swap straight ova.
Thanx
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 02-02-2005, 03:19 AM   #2 (permalink)
View anuthaCamry's Photo Gallery
i got a 93 with 3 dial-controls, one mechanical lever, 1 switch, and 1 servo-control switch.
I just lubed the mechanical hot/cold mixer linkages with some spray silicone lubricant with some very handsome results... if it ain't much trouble, try to download the pertinant info in the techinfo website, I do not believe that there is any other online source of info as in-depth as that - at least as far as climate controls are concerned.
anuthaCamry is offline   Reply With Quote
Old 02-02-2005, 04:22 AM   #3 (permalink)
VeeZed
For sure..sounds easy to fix up..just wanted to know if the updated model uses the same wiring and mounting system..i'm pretty sure they would..just wanted to know other opinions.
