Tire size. Need Advice! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2005, 06:48 AM   #1 (permalink)
Yota4Life
View just2asian's Photo Gallery
I have some 18's that I just recieved. Two of the 18's have 235/40 on them. I was thinking about putting them on the back and putting 225/40 on the from. I was told that the 235/40 won't fit on the back, but will fit on the front. Is this true? Thanx in advance for any feedback.
just2asian is offline   Reply With Quote
Old 02-02-2005, 07:16 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
How wide is the rim and what's the offset?
Please read the links below
tire dimension explained
wheel tech
tire size calculator
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 02-02-2005, 08:20 AM   #3 (permalink)
Yota4Life
I'm not positive of the offset, but the rims i believe are just 7.5 or 8 wide.
Old 02-02-2005, 08:48 AM   #4 (permalink)
EKam's Avatar
Well all those numbers make the difference whether or not they'll fit.
If you don't know then we can't help.
Old 02-02-2005, 09:08 AM   #5 (permalink)
Yota4Life
The only thing i Know is that the rims are ICW 219s they are 18x7.5 and the offset i believe is 40
Old 02-02-2005, 11:57 AM   #6 (permalink)
View Calvin327's Photo Gallery
They should fit, most likely you'll need spacers for sure. Otherwise you'll go through tires like crazy.
Calvin327 is offline   Reply With Quote
Old 02-02-2005, 02:17 PM   #7 (permalink)
Yota4Life
Is it because the tires will rub on the inside of the wheel well? Anyone know where I can get some spacers?
Old 02-02-2005, 02:36 PM   #8 (permalink)
EKam's Avatar
Can you please explain to me why spacers will effect tread wear of the tire?
Old 02-02-2005, 03:00 PM   #9 (permalink)
The Other White Meat
terrastrife's Avatar
your tyres MAY rub and get eaten by whatever therye rubbing against.
7.5" wide +40 you may rub the strut at the rear...what gen camry?
terrastrife is offline   Reply With Quote
Old 02-02-2005, 03:11 PM   #10 (permalink)
EKam's Avatar
Wow I didn't know "go through tires like crazy" means rubbing. He could've just use 1 word instead of 5. Someone needs to go back to english class.
To get back on topic, you're not suppose to have different size tires on front & rear. You should use the tire size calculator to find the appropriate tire size.
