Glad it runs now!
Car belts do not stretch, so there is 0 break in.
87 octane is what the engine was made for. Higher gasoline does not enhance performance, tho might contain more cleaning agents. (Either way the insides will look crappy... Family car engines never make enough heat to burn deposites out.)
Your friend is correct. Stick with Denso, or NGK spark plugs. Anything else will probably run pretty crappy.
i was regarded as a gross pollutant since my car failed the 0-35mph test. what can i do to correct this so that i can pass this year?
Find out the cause.
1) Does your EGR system work?
2) Is your cat convertor functioning?
