possibl to switch from 9004 harness to like h7? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2005, 06:22 PM   #1 (permalink)
View alex86's Photo Gallery
I was just wondering if its possible if I can switch the 9004 harness to a different one. yes i noe housing isnt gonna fit but just wondering cause i might just switch to like 9007 or something.
I have been given a sickness from the doc... Obsessive Compulsive Camry Dissorder... certifiable
alex86 is offline   Reply With Quote
Old 02-02-2005, 06:57 PM   #2 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
you can swap harnesses easily, but you'll need to upgrade the wires to a heavier gauge wire as well, if you intend on using a high-wattage headlight.
you'll also need to retrofit everything in the housing.
at that point, you might as well go with HID's.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 02-02-2005, 07:40 PM   #3 (permalink)
meh. i really want to just do somethin because if u noe the really poor quality of illumination of 88 camrys you would try doin somethin about it. yes i got fogs but they work some wat. using PIAAs right now have a pair of Euro Lightz or Euro Dezign bulbs they work too. the only thing im gettin upset is that my driver side beam is so much brighter than my passenger side. i did get smacked in but body shop pulled it bak out would that cause this? my friend took his dvm nd tested the little plugs(3 of em in the plug) nd the middle one wasnt gettin any current.
