S2000 Antenna Conversion, PICS!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2005, 08:29 PM   #1 (permalink)
Not a Noob!
View funboy102's Photo Gallery
Talking S2000 Antenna Conversion, PICS!!!
Sup guys,
I just finally took pictures of my S2000 Antenna conversion, how do you people like it?
From the front side
From the right side
From the rear end
Took about half an hour to do.
BTW, if the car looks dirty, it's because this picture was taken in the morning when dew is still on your car
1999 Solara SE V6
funboy102 is offline   Reply With Quote
Old 02-02-2005, 08:37 PM   #2 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
thats nice...too bad my antennas on the driver side corner of the roof....and its screwed down......
coolchu001 is offline   Reply With Quote
Old 02-02-2005, 08:48 PM   #3 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Ah, you must have a DX!
Looks good, i will do that when it warms up a bit.
5 Lug Corolla WHAT?
Old 02-02-2005, 08:57 PM   #4 (permalink)
View bowlofturtle's Photo Gallery
^ same here. looks really good. How was the process of removing to old one? And how firm is that s2000 antenna on?
96 Camry Le I-4
bowlofturtle is offline   Reply With Quote
Old 02-02-2005, 09:24 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
i like the driver a-pillar antenna better :P but thats just me, mines never up anyway
terrastrife is offline   Reply With Quote
Old 02-02-2005, 09:30 PM   #6 (permalink)
Not a Noob!
Removing the old one was suprisingly easy. You just have to unscrew the top part of the antenna, open up the quarterpanel covers on the inside of the trunk, and remove the nut from the other side. After that, remove two nuts and bolts that holds the stock antenna assembly to the car chasis. The stock power antenna slides out easily. After that, just do the reversal, this time with the S2000 antenna.
1999 Solara SE V6
Old 02-02-2005, 09:53 PM   #7 (permalink)
its not an s2000 antenna (probably).. just kinda the same should be a non motorised antenna conversion! thread :P~
Old 02-02-2005, 09:58 PM   #8 (permalink)
no its really a s2000 antenna. well in the FAQ its stated there. u need a celica bracket with a s2000 antenna.
96 Camry Le I-4
Old 02-02-2005, 11:02 PM   #9 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
awesome, keep up the good work
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 02-02-2005, 11:09 PM   #10 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
I don't really like the antennas with the wider part of the rubber boot. Would prefer the ones that stick straight up but I guess you'd need an extra part for that.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 02-02-2005, 11:14 PM   #11 (permalink)
Always Under Construction
View whocares04's Photo Gallery
my conversion is like the same...i took and S2000 antenna and put it on my stock power antenna and just unpluged the power to it...it doesn't look as clean but it stands up straight not at an angle (not that it doesn't look clean)...if i had a digital camera i would show u...but i'm cheap and don't have one (does some1 wanna give me one )
looks good...S2000 antennas are like 15-20 bucks, but i got mine free after the carwash i work at somehow took one off
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 02-03-2005, 06:54 AM   #12 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I gotta try this conversion thingy. Of course it won't be a S2000 since I can't get that here, but it'll look similar.
http://www.xclusive.bz
Old 04-21-2005, 04:15 PM   #13 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Anybody share the sucess of using the S2000 mast on the stock power antenna, without modification except unplugging the power?
Thanks.
mandyfig is offline   Reply With Quote
