did my motor mount disintegrate? not 56k friendly! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2005, 10:55 PM   #1 (permalink)
View anuthaCamry's Photo Gallery
Question did my motor mount disintegrate? not 56k friendly!
My car be a-shaking at 80 mph and over, and I'm trying to narrow down the cause, well I'm kinda curious as to whether or not a bushing is missing from the lower motor mount because it looks like there is a perfect place for one. Just want a quick reply as to whether or not there is something missing or not, because it looks like there is but a picture is worth (and will likely generate) a 1000 words...
It is really only visable on the last picture, the other ones are just for orientating. 93 4cyl
anuthaCamry is offline   Reply With Quote
Old 02-02-2005, 11:17 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
I think you got it.
On an ES 300 it looks like this (picture in a few)
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-02-2005, 11:26 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
ok i cant asnwer this but wow that series of pics was bloody helpful :P
terrastrife is offline   Reply With Quote
Old 02-02-2005, 11:36 PM   #4 (permalink)
Toysrme's Avatar
Cool
You have a broken transaxle mount. You definately need to check every other engine mount also.
That's the best I can do at night, in rain.
Now with Turbo!
Old 02-02-2005, 11:45 PM   #5 (permalink)
they don't look enough alike to make a really good comparison
your car has the 6cyl, and looks like it's designed differently
Old 02-03-2005, 12:39 AM   #6 (permalink)
Toysrme's Avatar
Cool
It is designed differently, but I'm not so sure yours is suppose to ahve rubber comming out of the top of the mount.
Put something under the mount and see if you can move the transmissin around some.
Now with Turbo!
Old 02-03-2005, 12:48 AM   #7 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
hmm, my cars shakes at 80 and above also, i always thought it was my tires, but maybe i got the same problem as you have.....gosh i hope not
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 02-03-2005, 01:09 AM   #8 (permalink)
I'm thinking that it's loose nuts bolts, I'm thinking that I might just retorque everything I can find. Some of the bolts come loose on toyotas and they are supposed to be retightened as part of regular maintenance.
Maybe it's the bearings, but I cannot detect any play pushing the hub in and out., I don't know if there is another way to check for play, or if the hub bearing torqueness matters because I'm not sure if it was tightened to spec.
I just bought me a torque wrench for $12 so after I test it I think I'll use it. I already found one loose bolt on the stabilizer bar.
check this out
Old 02-03-2005, 06:29 PM   #9 (permalink)
View sr20de2's Photo Gallery
No there is nothing missing just worn out mine was the same way @200,000 miles.
sr20de2 is offline   Reply With Quote
Old 02-03-2005, 06:38 PM   #10 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
check this out
HA I got that same one...lol
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
