Can't disconnect the Shift Knob.. HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2002, 12:32 AM   #1 (permalink)
View IrishGuyute1's Photo Gallery
having trouble figuring out how to get rid of the shift know in my 96 camry LE.. got all the screws off but the knob won't lift off.. seems like the O/D button and the wire attached to it is still connected. I could not take out the little compartment with the o/d button to disconnect the wire. how do i do this?... i want a C/F knob soo bad.
IrishGuyute1 is offline   Reply With Quote
Old 07-13-2002, 04:33 AM   #2 (permalink)
View woshiagni's Photo Gallery
I'm not sure if the knob setup is similar to the one on the Gen4, but in case it is...
You need to pull off the gear indicator cover and reach down to disconnect the OD harness - it's to the right and forward of the shifter assembly, near where the passenger's left foot would be. If you're too lazy to do that, you can also cut the wires leading to the OD button and solder them to an aftermarket switch or your new shift knob.
woshiagni is offline   Reply With Quote
Old 07-13-2002, 10:02 AM   #3 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
You have to cut it in the Gen3
Silver Streak is offline   Reply With Quote
Old 07-13-2002, 10:15 AM   #4 (permalink)
if i cut it where should i cut it and how do i reconnect it? i am not an electrical genius.. i know not much about automotive electronics or any electronics for that matter.
Old 07-13-2002, 10:31 AM   #5 (permalink)
Banning is an art.
You have to get a switch and simply connect the two wires to it. Like this....
_________________
Henry
Visit my Camry Website!
<font size=-1>[ This Message was edited by: Silver Streak on 2002-07-13 11:31 ]</font>
Old 07-14-2002, 03:08 PM   #6 (permalink)
View Stylus_gen3cam's Photo Gallery
what are those switchs in middle there silvercam?? what do they do?? (like dat nice metalic trim look)
Stylus_gen3cam is offline   Reply With Quote
Old 07-15-2002, 09:57 AM   #7 (permalink)
Banning is an art.
Left switch = O/D
Right switch = Controls amp 1
Big red one = Controls amp 2
