Power doorlocks and windows not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2005, 06:01 PM   #1 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Except the passenger side power door lock switch does. I checked the fuse under the dash, the squarish rectangular one (#34 in the book), that one is fine. When I pulled it, the passenger side power door lock switch didn't work, so I know the fuse is fine. Yesterday I ran a new RCA for my subs so there is a possibility that I may have hit/disconnected somewhere in that area (more likely the kickpanel area), but I checked to make sure all the plugs were in and they seemed fine. If its not any of those wires or plugs, my only guess is possibly another fuse, but I don't know which one that might be. Gonna have my installer buddy over here tonight to check it out, but if you guys have any ideas please let me know incase we can't figure it out.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 02-04-2005, 10:00 PM   #2 (permalink)
Stealth's Avatar
desperate bump for help
and a little more info:
checked fuses, and tried replacing the main power relay, everything seems fine... I have a feeling its the wires or the switch since the power locks work if you use your key or the passenger side switch.
Old 02-04-2005, 11:23 PM   #3 (permalink)
View 500KCamry's Photo Gallery
Under the dash, where the fuses are, is one of those 30A pink colored fuse links. It provides power to the door lock, power windows, power seats and moonroof.
You have to take the under dash panel off, then a heating duct, to access it. 15-30 min work.
I hate working under the dash, my beer gut gets in the way.
Oops, I didn't read your post properly.
Sounds like a wiring break, in the door wiring flex boot.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-04-2005, 11:39 PM   #4 (permalink)
Diablo
View GaviN's Photo Gallery
My locks occassionally dont work but I just turn the car off and back on and they mysteriously work again, lol
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 01-20-2006, 10:55 AM   #5 (permalink)
View jaberblanchard's Photo Gallery
500KCamry,
How do you get the heating duct out of the way? I undid one plastic clasp at the top but cant get it to get loose enough to remove. I dont want to break it. But I need to get to the fuses.
My beer gut is making the job very difficult.
jaberblanchard is offline   Reply With Quote
Old 01-26-2006, 10:34 PM   #6 (permalink)
Stealth's Avatar
Yank hard.
Fixed the problem a long time ago, just forgotten to plug in the driver's side door stuff behind the door card.
