Confusing Timing Belt Guide - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2005, 11:34 PM   #1 (permalink)
View drugal's Photo Gallery
I need some help with installing this timing belt guide. Here's my problem: The crankshaft has two bumps/extrusions: one for the timing belt pulley, and one for the alternator pulley. When I install the timing belt pulley all the way in, the bump doesn't extend beyond the pulley. The notch on the timing belt guide has nothing to sit on, and I don't know what to do with it.
Does it sit loose on the crankshaft, or what? Wouldn't it grind away at the shaft eventually?
This picture should explain it better. You can see the guide hanging off the oil pump pulley to the left.
Link to picture.
I need to get this figured out tonight!
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 02-04-2005, 01:38 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The guide just sits around the crankshaft. Its more or less just a washer/shim.
See step #6 in the link below:
http://yotarepair.com/3S-FEtimingbelt.html
"Skoolin' the unlearned!"
