FYI for Honda-Acura Rims vs. Toyota-Lexus
Have figured out:
Bolt patterns are the same, 5x114.3
Offset depends on actual Rims. CRV Rims will not fit 95 Camry. Brakes hit the rims, will need spacers, but not recommended.
Hub Diameter for Toyota-Lexus: 60 mm.
Hub Diameter for Honda-Acura: 64mm.
Those of you in the know, correct me. But Toyota Wheels will not fit Honda, unless you make the hole bigger to fit the hub.
I can use 215/60/16 on the 95 Camry without rubbing issues. Total Wheel diameter is 26" vs. 24.8 OEM for Camry. Some speedometer discrepancies will occur.
It has been quite educational. I thought that the Lexus (ES300) wheels will not fit my Camry, but works like a charm.
