Okay as posted earlier, the cat back was quite a success. I had the "Unorthodox" underdrive pulley installed this week and took it to dyno yesterday evening.
As luck would have it, it was raining like crazy and very humid. Overall readings were a little lower than normal. Now one important variable here is the guy doing hte dyno run. I've had the same guy do my first 2. However this time that guy wasn't there and another guy did it for me. He wasn't as good in my opinion. Anything below 4000 RPM was inaccurate and had to be trashed. He got on the pedal really soft until 4000 RPM which is when he floored it. So under 4000 RPM it looks like I have NO POWER! However here's the results of the pulley:
Peak HP was up a bit... 2 HP or so and torque remained the same, at peak again. HOWEVER, at higher RPMs, there was as high as a 6 HP and torque increase. In other words, my HP and torque curves have flattened out a bit, at the top end at least. Who knows what the real effects were at lower RPMs (under 4000). But from driving it, the RPMs climb faster, obviously I'm making more power at higher RPMs now than I used to, so you don't get that steep power drop after about 5000 RPM.
That's it for now. I don't know what my next mod should be. I think I want a high fow cat and maybe work on the intake a bit to make it cold air or ram air. I dunno yet, because the exhaust was amazing and I don't want to disturb the balance with backpressure and all that, by incorrectly modifying the intake.
I might just ask Richard at Brullen to take a look at my cat since he did my exhaust. I'm sure he will find a way to modify cat without losing benefit of cat back and give more power overall.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
