there is no advantage to pulling the cooler hose as opposed to doing it the right way. both will take about 10 quarts to replace 90% of the oil, even if your transmission pump runs outa oil, there will still be oil in the TC, even more when it's spinning.
I've dropped and worked on trannies before, you just can't drain it on the car. pulling the hose is just confusing way to try to flush it ...
If you run outa oil (in the pan, there will still be lots in the TC) you're looking at some metal to metal grinding in that pump which is probably all metal, and designed to never run dry.
