Steering Vibration @ 130 km/hr - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2005, 04:20 PM   #1 (permalink)
View taimurakhter's Photo Gallery
Angry Steering Vibration @ 130 km/hr
I have camry 2001 with 215/50 R17" rim. Couple of weeks ago I rotated my tires (rear to front in the same side). After rotation, when I drive over 130 km/hr, I feel slight vibration at my steering wheel.I went to the store (Wheel Direct, Toronto) to balance my front tire. they said that my front tires are balanced and i need Hub Rings to reduce the vibration. They installed the hubrings on 4 wheels but I still have the same problem at 130+ km/hr.
Do you think I need 4 wheel balance from the Toyota Dealer ? My idea is may be dealers do better balancing than the after market Rim stores.
Before the tire rotation, I had no vibration even at speed of 160 km/hr. Now the vibration starts at 130 km/hr.
Should I check my tire pressure? How much PSi I should have for teh performance tire (215/50 R17")? 40 psi??????
taimurakhter is offline   Reply With Quote
Old 02-06-2005, 04:42 PM   #2 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
for balancing it would depend more upon the tech doing the actuall work, not the place where it gets gone, cause all they do it mount the wheel on the machine, then put the weight where the comp tells it to.
and if they added hub rings but that had no effect, then the hub rings could be the wrong size, therefore having little to no effect on your problem
or you could just not drive over 130
Fresco Bob is offline   Reply With Quote
Old 02-06-2005, 05:13 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
techs may need to balance both the outside and inside rim of wheel to get a better balance. I had the same problem at 90mph and above, but balancing inner and outer side of wheel cured it. of course I went to someone I knew personally and he made sure things were kosher.
The Jedi Speeder at CarDomain
Old 02-06-2005, 05:28 PM   #4 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
your real problem seems to be that you have aftermarket rims, which, on a toyota, won't be hub centric, because toyota has comparitively tiny hubs on it's cars. and aftermarket rims are made to fit lots of types of cars. try getting some toyota rims you like better. (less choices, better fit, no vibration)
S92GT is offline   Reply With Quote
Old 02-06-2005, 07:30 PM   #5 (permalink)
I did not have the vibration with the same wheel before tire rotation. Why would the vibration appear after the tire rotation.Don't you think the current front tires(which are form the rear sides) are little bit off balance?
What Tire pressure should I use?
Old 02-06-2005, 07:32 PM   #6 (permalink)
Old 02-06-2005, 09:21 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
check each of your rims carefully....it could be a cracked rim..
I used to get vibrations at 140, and when I got my winter's switched onto my 17s, they found out that one of my front wheels were cracked....
HaHa
Old 02-06-2005, 10:13 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I'm not positive about your tire pressure but it would be between 32 and 35psi. the tires they moved to the front could still be off balance.you might want to do as Eye8Pussies suggested and check the rims for cracks and warp. but I bet they just need to be fine tuned balanced. especially aftermarket rims
