Hi!
My 1990 Camry V6 makes a humming sound while stationary at a stoplight. The sound is usually heard coming from the transmission or differential while the gear selector is still on Drive. When the sound gets louder, I would then shift to Neutral and the growling sound disappears. This always happens when I'm slowly approaching an intersection or I'm on a complete stop. The sound is more pronounced when the car is already stationary and the gear selector is still on Drive. I don't know if this is normal. I just inherited this car recently from my late grandfather. Other than this annoying transmission sound, the car runs fine.
Is this something I have to live with, or is the sound telling me that the transmission is going to be a goner pretty soon.
Thanks for any input.
I just had the transmission serviced. (Drain, Change fluid, Cleaned Filter, Replaced Gasket)
The sound is still there though.
If I were to change the transmission fluid to synthetic, any recommendation?
Thanks
live with it, invest in a louder stereo, or fix it....but it ain't worth fixing if you're having others do the work, you could try replacing the transmission from a wrecked car.
just look for the wreck that's bashed because at least you know why it's in there..
switching to synthetic will do nothing about that noise, it will just reduce the already high chance tranny failure....
So drain/fill the differential.
Also, if you didn't have the fluid flushed, you didn't change any sizeable amount of the fluid out on the first drain and fill...
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
You said you just had it drained.
Are you 100% positive it was flushed, or that they just dropped the pan.
