99 Camry Noise at 40 and 60? Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 12:42 PM   #1 (permalink)
View craigferriter's Photo Gallery
I guess the title of this post says it all.....
It's kinda of low pitch humming noise, pretty loud, though.
Starts at ~ 40-43 mph and comes back again ~ 60-63. Only these speeds create this noise!
Please help before I bring in tomorrow for diagnostics!
Thanks in advance!!!!!!
craigferriter is offline   Reply With Quote
Old 02-08-2005, 06:11 AM   #2 (permalink)
No ideas out there? Anyone?
Old 02-08-2005, 10:24 AM   #3 (permalink)
View toysarefun's Photo Gallery
Its your CV axles, get under there and look at the CV boots to see if they are cracked or split open. Its a fairly cheap repair, (not at the dealer though) I was able to get both my outer axles replaced for I think $350ish.
toysarefun is offline   Reply With Quote
Old 02-08-2005, 04:07 PM   #4 (permalink)
Gameroom cash: $304355
Check the tires for cupping. This can produce a sympathetic vibration at various different speeds. Run your hand over each tire. If you are not sure what you are looking for, take it to a tire shop and ask them to check for you. Also, look for a lost wheel balancing weight which may have fallen off one of the tires. Don't forget to check both sides of each tire.
Mike
Old 02-27-2005, 12:47 AM   #5 (permalink)
View techguy's Photo Gallery
Had a similar one at 65 mph. It was a rear bearing that had to be replaced. I have extended warrantee so I was only out $150 for the deductible. The dealer charged $500 to the insurance.
techguy is offline   Reply With Quote
