Originally Posted by whocares04
what kind???
one of his earlier posts from a while back, I think he has more stuff, but he can answer that for you
might have forgot some stuff....
Performance:
TRD supercharger at 7psi
Weapon R short ram intake w/ CAI extension
TRD radiator cap
TRD oil cap
15" Steelies with BFG 225/50/15 drag radials
Ignition Solutions plasma booster
NGK blue wires
NGK BKR7E-11 spark plugs
Custom 3" cat back exhaust
Full 2.5" y pipe with no cat
TRD short shifter
ACT clutch kit
Findanza 10lb aluminm flywheel
Throttle body coolant bypass mod
Speed Source shifter cable bushings
Apexi Rev/Speed meter w/ speed limiter removal and G sensor
Mofified stock fuel pressure regulator @59psi
94 supra 2jz-ge fuel 315cc injectors
Field HYPER SFC fuel computer
Walbro 255lph fuel pump
Redline Water Wetter additive
Knock Sensor Relocated to front engine hook
Mobil 1 snthetic gear oil
Mobil 1 10w30 engine oil w/ Outlaw additive
Suspension:
TRD solara springs
TRD bilstein struts
Whiteline front and rear sway bars
TRD front upper strut tower bar
Energy suspension front and rear control arm bushings
Brakes:
Stillen Cross drilled rotors
TRD pads up front
ATE brake fluid
Goodridge stainless steel brake lines
Exterior:
TRD 7 piece body kit
Shaved emblems
Trenz polished billet grille
Supercharged badge on the back
Clear corner marker lenses
Interior:
Autometer Dual gauge pod
Autometer single gauge pod
Autometer EGT gauge
Autometer air fuel ratio gauge
Greddy 60mm Boost gauge
Apexi Shift light
Initial K indiglo gauges
APC polished aluminum gauge bezel
