Cheap mods - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 04:16 PM   #1 (permalink)
CamryGuy14's Avatar
View CamryGuy14's Photo Gallery
Cheap mods
Anybody know of any cheap ways to get extra power out of the '94 1MZFE engine? I ran a 17.1 at the drag strip last week and I know I should be faster than that. I'm taking some weight out of the car (removing spare tire and bringing less junk) and I'm putting premium in the gas tank. I think I'm gonna go for a K&N or TRD air filter. Any opinions on those filters? Thanks.
'94 Toyota Camry LE V6 ***FOR SALE***
225,000 miles and rising
<<cardomain>>
CamryGuy14 is offline   Reply With Quote
Old 02-07-2005, 04:17 PM   #2 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I have heard many people say here on TN that using higher then the recomended octane (87 for our cars), does not yield any beifit. It may actally make it worse.
5 Lug Corolla WHAT?
Old 02-07-2005, 04:30 PM   #3 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
^^^^ True, but if you are running a strip at WOT, you might want to up your octane a little. Not premium, don't go over 91. 89 should work nicely. You might also want to consider getting some better mods than filters if you wanna run at the strip, like exhaust, headwork, SAFC, ect. Some good tires or drag radials might help also.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 02-07-2005, 04:31 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
thats correct-the higher octane is to detour detonation in high compression engines. It's best to use the recommended octane. I prefer the cone type K&N filter. it flows alot better and will yield a better throttle response.maybe advance your timing alittle. other than that I don't know alot of cheap ways to get more HP from a stock engine
The Jedi Speeder at CarDomain
Old 02-07-2005, 05:30 PM   #5 (permalink)
CamryGuy14's Avatar
I didn't think there would be many cheap things I could do. I'll have to save up some money to buy some fun toys for it. As far as the octane, my car actually does perform better on premium than on regular. The lexus es uses the exact same motor and they recommend premium in their owner's manual.
<<cardomain>>
Old 02-07-2005, 06:09 PM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
....... you know i always though the trd was just a rebadged k&n .... and that has been coverd on here before
also toyota dose recomend the use of 91 octaine with a compresion ratio of 10.5 i def say keep higher than 87 ... actualy my cam is bitch if i use anything lower than 89 .....
if you havent try tuning up your engine which includes that little bottle of injector cleaner and a whole top end cleaning too.
^ and leaving it that way!
Old 02-07-2005, 06:20 PM   #7 (permalink)
View Adam Housley's Photo Gallery
You will make more power with the lowest octane gas. As stated earlier, higher octane gas resists detonation, and therefore creates less power. The reason that there are higher octane gasses are for different compression ratios in engines and climates. 87 octane is fine until 10:1 compression aprox. in most situations.
1979 MGB V6 Tourer, 1993 Camry LE
Adam Housley is offline   Reply With Quote
Old 02-07-2005, 06:49 PM   #8 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
To resist premature spontaneous combustion. You don't want it to detonate based on compression alone, you want it to detonate based on spark. If it detonates before TDC you're losing power and so forth.
With this said, 87 octane I doubt will be the best for 1MZ-FE's.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 02-07-2005, 07:22 PM   #9 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
SEARCH for performance mods... They've been covered to death. There are a good dozen cheap ones that will get you into the mid 16s if you combine them.
1mz-fe's do "require" to "suggest" the use of 91 octane.
The car doesn't know the differance... All it does is detect pre-ignition. When it sees it, it retards the timing until it goes away, waits a very few seconds, and starts putting timing back in until it's back to base timing, or the pre-ignition comes back.
It's as simple as if you run 87 octane in your car, and there is no pre-ignition; your reasons for using higher grade gasoline are fairly well nullified.
Run the next tank out, pop the hood while your car is filling with 87 octane, and pull the EFI fuse out. Finish fueling, pay, put the fuse back & close the hood. Then drive the son of a bitch.
If there is mild pinging, never use 87 again. If you can't tell the differiance, you've been using the wrong gas for the life of the car, and should feel like a total dumbass
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-07-2005, 07:34 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
damn, kinda harsh, but funny. and with gas prices these days i wouldn't spend anymore on fuel than i had to. BTW, does TRD make a cone type filter?
Old 02-07-2005, 07:49 PM   #11 (permalink)
View auto_newbie's Photo Gallery
get a injen cold air intake
1993 Camry V6 Auto - 236000 kms..
need an engine and tranny swap..
Current Mods:
Tokico Shocks, B+G Sports Springs, Ractive Tower bar, Fireball Muffler
Future Mods:
GT-wing,steering wheel, bucket seat, 16' rims, toyo RA-1, Injen Cold Air Intake
auto_newbie is offline   Reply With Quote
Old 02-07-2005, 07:50 PM   #12 (permalink)
Always Under Construction
View whocares04's Photo Gallery
it recommends 91 for optimum performance....which means 87, 89 and your car will run just fine and have enuf power but i supose 91 would work better at the track.
just answer your own question...use 91 next time at the track and see if it makes a noticeable difference...i would guess maybe more than .5 sec.
there are no "cheap" mods...just look at the "performance chips" on ebay that will add 20+hp for $0.99
Cold Air Intake (custom or AEM, etc.), custom exhaust, and so on...building a quick and fast car is not quick or fast or easy and DEFINEATELY NOT cheap....just stay to the forums and you'll get there
edit: just noticed ur sig camryguy14...187k+ miles, maybe u shouldn't drive it so hard i'm only at 106k but still....
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 02-07-2005, 08:31 PM   #13 (permalink)
Pulling Out
k, 1MZ. I thought he had 5SFE. In that case, 91 is your best bet, if that is what's recomended.
Old 02-07-2005, 09:33 PM   #14 (permalink)
View anuthaCamry's Photo Gallery
I've noticed that the gen3 1mzfe accelerates faster on 91 as opposed to 87. You could try using octane booster, but I really don't know if that will work ... but doesn't hurt to experiment.
You should already know this but:
Turning the A/C off during runs will make a big, big difference (I turn it off on my 4 when merging ).
Inflate your tires to proper inflation, or at least proper inflation for the back tires.
anuthaCamry is offline   Reply With Quote
Old 02-07-2005, 09:59 PM   #15 (permalink)
also make sure u power brake...(don't drop it from neutral or else but u probably already knew that.)
turn of all accessories, remove EVERYTHING unnescessary from the car and even take out the back seat (the 'seat' part, just pull up on the front and it'll pop up).
-Matt
