Interesting info on Engine and Transmissions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2005, 05:33 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Was over at ToyMods.com.au and a piece of info was posted that I found interesting.
"The S, VZ, MZ and L engines all use the same bellhousing pattern, however on twin {think he means quad} cam VZ and MZ engines, the starter motor gets in the way of one of the heads."
Can anyone back that up?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 02-08-2005, 12:43 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i know the 3s, 1mz and 3vz have the same housing, actually never heard of the L series
now i just wonder who up for swapping in the 5vz if that is true
i also would like to know if they have a FW tranny for an R series engine
^ and leaving it that way!
Old 02-08-2005, 02:04 PM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
5mz???
try 5vz or 3mz.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 02-08-2005, 04:53 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
doh ...... zoni back!
well i ment 5vz .... since that has a trd supercharger .......
Old 02-08-2005, 05:19 PM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The starter motor doesn't get into the way of the heads on a 3vz-fe. It's way out of the way from either one...
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-08-2005, 11:21 PM   #6 (permalink)
View 91MR2quickNA's Photo Gallery
The GR series might use the same pattern as well. The U151E (5spd auto) is used on the 1MZ/3MZ, where the 93+ E153 bolts right up to, so it's possible to conclude that the GR series engine can use the E153 since it also uses the U151E.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 02-09-2005, 12:48 AM   #7 (permalink)
VeeZed
Interesting...so, if a the E153 works on MZ and VZ blocks...and the U151E is used on MZ blocks..then the U151E could be used on 2VZ and 3VZ blocks...hmmm
Old 02-09-2005, 06:07 AM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
but your problem would be that the U151E is an auto tranny and your ecu might not be able to drive it right
you need the 6 speed manual i think they have somewhere ......
