HELP-------Battery Drainage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2002, 01:31 AM   #1 (permalink)
View dark_pietro's Photo Gallery
I have a question... I was driving my car yesterday and my battery was dead, but this was the third battery that ive bought in the past two weeks..When I cut my car off if i dont unhook the battery the battery gets drained, do you know what the problem could be?
dark_pietro is offline   Reply With Quote
Old 07-15-2002, 02:41 AM   #2 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
u may have hooked something up that is still drawing current off of ur battery even though ur car is off best thing to do is check ur fuse for power when ignition is off.. to see wat is causing the drain another thing is maybe ur alternator maynot be charging ur battery enough.. check for voltage and current regularities.. charging voltage for the alternator should be 14 volts not sure on amperes cos dont know wat kind u got..
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 07-15-2002, 03:39 AM   #3 (permalink)
Its a 88 Camry all Trac Le......How much would it cost 2 get it fixed?
Old 07-15-2002, 08:54 AM   #4 (permalink)
View DustinTRD's Photo Gallery
you need to have VAT-40 testing done
should be like 50 bucks, then if you need repairs, wow expensive! Do you have an amp hooked to the battery, if you dont put it on a switch, it will drain the battery!
DustinTRD is offline   Reply With Quote
Old 07-15-2002, 09:11 AM   #5 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Most likely it's your alternator...get it checked out for sure....
Silver Streak is offline   Reply With Quote
Old 07-15-2002, 11:23 AM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
dead alternator or parasite
Nick is offline   Reply With Quote
Old 07-15-2002, 03:38 PM   #7 (permalink)
WHOA back up....Alright you said that if i had an amp hooked str8 up to the battery then it would drain it right? Well on the positive cable of the battery there is a little case and it has a 30 amp 80 amp and then a 40 from left to right, its hooked up directly to the positive cable....I will take a picture of it and put it on here...
Old 07-15-2002, 03:50 PM   #8 (permalink)
Banning is an art.
As long as your remote signal to turn on the amp is hooked up to the stereo and not a constant positive, then you're okay. If you got it installed professionally, then most likely it's not the amps...I don't see how a professional could make a mistake like that.
Again, get your alternator checked out...
Old 07-15-2002, 04:07 PM   #9 (permalink)
Alright then could my amps have anything 2 do with my spedometer not coming on>?
Old 07-16-2002, 05:05 AM   #10 (permalink)
Blazin...
speedo not comin on?? like how?? thelights arrent on?? or the speedo not movin?? if lights u couldve burned out the light bulbs behind ur cluster.. if not have ur car checked out if ur speedo dont move its expensive good luck..
humpty
Neoscepter
Old 07-16-2002, 08:42 AM   #11 (permalink)
Banning is an art.
I love playing these guessing games, especially when you're trying to help someone.
Old 07-16-2002, 12:10 PM   #12 (permalink)
Blazin...
yeah tell me about henry!!! hehehehe its like playin games here... ppl should be more specific with their questions... we're not mind readers u know hehehehehhehee
Neoscepter
Old 07-16-2002, 01:17 PM   #13 (permalink)
Banning is an art.
Well, my magic 8-ball said to check the alternator so I guess you better! :grin:
Old 07-16-2002, 08:38 PM   #14 (permalink)
Aight then thanx....Like the whole damn speedo wont come on at all, niether does the odometer..the Alternator was puttin out the right power, but i found a lot of wires that were grounded....Does anyone know how I could personally fix the speedo and odometer?
Old 07-16-2002, 09:39 PM   #15 (permalink)
Banning is an art.
Humpty, you better take this one...my magic 8-ball seems to be broken. :smile:
