A$$ load of questions...SOrrY
Ok, sup guess and gals my 3rd gen is parts away from finshing its turbo kit. So instead of buying a brand new 300$ map senor. I was wondering, On 6 to 3psi will my stock map sensor work just fine if i dont mess with the boost .ALso what are the best injectors to use if i can use my stock sensor. Remember im not going over 6psi. Am i going to need a fuel pressure regulator .
PS- The things I need.
1- to know if I can save 300$
2- Does any one have there parts they would like to sell to me
toyota supra ct26 turbo-exhaust elbow/down pipe
injectors to run 6-3psi on a stock map sensor if
a better bov then this plastic pos
afr,boost, PAYPAL only
PSS- I have an apex afc installed already if that helps any
