Tackling the suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2005, 06:24 PM   #1 (permalink)
eeto........?
View _VVTi_'s Photo Gallery
Hi, this summer i'm determine to do a tokico and H&R setup. However, this will be my first big mechanical job for my camry, I just need a few question answered b4 I head on tackling my suspension.
First, aside from spring compressor, what other tools do i need? I want to get all the tools I need b4 start going at it.
Second, what other parts should I look into replacing while the suspension is apart already? Strut mount? Strut plate? RSB?
Third, IF i do consider having a shop do the dirty job for me. How much will I be looking at for labour? So i won't get ripped off...
Forth, where would I be able to find the best deal?
Fifth, and last... I see that H&R got 2 models of springs for Camry. What is the difference between OE Sport and Sport springs? Hopefully ppl with H&R springs can give me insight about this.
I won't be doing this setup till like summer, but I'm just trying to organize my plan of approach so I'll be all ready then summer is around.
THANK YOU!!
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
_VVTi_ is offline   Reply With Quote
Old 02-09-2005, 07:45 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
1) use the search function
2)there are a few companies that make CAI's (AEM and Injen i believe)
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 02-09-2005, 07:55 PM   #3 (permalink)
View 500KCamry's Photo Gallery
Get two 1/2" drive sockets for the two strut bolts. Can't remember whether they are 19, 20, 21 or 22 mm. The strut has some rubber insulators for the spring, for weather protecting the shock and a rubber shock bumper. Not sure what comes with what you are buying, but the original rubber components usually need to be replaced.
If you can rent/buy the spring compressor, it should be a DIY job.
I was just using the reusing stock springs when I serviced my struts and replaced the shocks. Don't laugh, but I made spring compressors using some 8" - 1/2 bolts, and the clamp casting from those U-electrical clamps for crimping wire to conduit. It takes time to compress and uncompress the spring, but three compressors can be made for about $10. Poos mans method, lol.
But for exotic accessories, a real spring compressor is the way to go.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-09-2005, 08:12 PM   #4 (permalink)
Use three per spring, lol.
01 XLE V6 310K km
Old 02-09-2005, 08:38 PM   #5 (permalink)
eeto........?
did searched doesn't answer my questions.
and.... CAI? since when CAI became part of the suspension...??
1994 Camry LE V6
Old 02-21-2005, 03:12 AM   #6 (permalink)
View {GodlightSoul}'s Photo Gallery
you can leave a deposit and borrow spring compressors from many chain auto parts stores.
{GodlightSoul} is offline   Reply With Quote
