I had Crower cams recut my stock camshafts and change the lift and duration. They did a great job...charged just over $100...but this is NOT a reweld. They do not add material to the lobe. Therefore, the base circle is changed. It just means that a valve job must be done at the same time and the machinist must know about the new base circle. Then he can cut the valve seats correctly. No biggie.
Sure...think about it. The base circle of the lobe is smaller. So the valve stem must come up a little higher (or you could get longer stems...but that's even more expensive for custom valves). The stem comes up higher by cutting back the seat more.
Oh I know what ya mean, but anybody sinking the valves into the head deeper needs their head examined, it puts the seat very near the edge and you loose a little compression, the easy way on these motors is just use a thicker adjustment shim and leave the head on the motor, thats just my 2 cents
I have to disagree with you. You're not sinking the valves into the head THAT far. It's not going to recess them into the head asignificant amount. Besides, using those larger shims are dangerous IF you want to be able to hit high revs. Those will break loose easier than you think. I think they're called valve caps...I forget if that's the correct name for them.
And you dont' find Toyota shims thick enough for this...but it would still be the same problem...too think to stay in the bucket at high engine speeds.
