you can open up the door panel and see what's what, 2 screws on bottom, two pins to push inwards on the latch side, 2 covered screws on hinge side below the air hole, 1 behind the red filter (92-93), 1 covered screw above the map box, and 3 on the armrest. pull/pry on the bottom only--- then lift it up before pulling it out.
could be a missing bolt on the regulator.
POWER WINDOW ADVICE: SAVE THE MOTOR!!!
The window attaches to the regulator assembly($300oem), the regulator assembly consists of the a contraption of loops and rails called the regulator ($50oem), and an electric motor ($250). you can unscrew the motor from the regulator if the motor is still good and then attach it to a new oem regulator,
life of an aftermarket regulator assembly ($150): 3-4 years, oem: 10 years
