Hey, rip off your dash trim take out the thing going into the back of the cig lighter or accesory plug, there is two wires, take a test light, find the +/- and splice into the positive wire. Then connect it to the pos wire on the neon tube or whatever, then take the neg wire from the neon and connectet it to somthing metal on the car to ground it. The light should work. then whereever you want to put the switch just cut the neg wire, and throw a switch in. You can cut into the positve wire as much as you want, i have tons of neons, and im only using the one wire from the cig lighter. There is a bonus it is on a fuse, so your neons wont blow up! Any questions email me at dleich@rim.net
