Replace PS tank..Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2005, 11:51 PM   #1 (permalink)
View rainman's Photo Gallery
Arrow Replace PS tank..Help!!
The PS reservior is leaking at the In and Out ports, I cannot confirm whether it is the PS reservoir itself, or the hoses that has cracks at the place where it connects these ports. Any idea how to confirm this.
Searched everywhere but could not find anything on how to replace the PS reservoir.. Any ideas...Can all the liquid be drained from the PS system, if so what abt the air that gets in, is it OK.
Also, the dealer has PS fluid without labeled ATF, but the Auto Tranny fluid is ATF.. is it fine to use this PS fluid without the label or can the Tranny fluid be use..?
rainman is offline   Reply With Quote
Old 02-12-2005, 04:33 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i doubt it your resivor if anything it might be your clamps, i cant rember how the are on this car but if you dont tighten them with a screw replace them with one that you can.
for just the clamp replacement fully un do the clamp and then slip it on over where the old one was dont take the line off.
ps, atf, it's all the same
^ and leaving it that way!
Old 02-12-2005, 09:40 AM   #3 (permalink)
Thanks!! Chronoti Will do and see if that helped...
