Power Window stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2005, 08:56 AM   #1 (permalink)
View Camry093's Photo Gallery
Question Power Window stuck
Hey Everyone,
My 93's rear pass side window is stuck down. It has no power from the master switch and the switch at the door will only lower it. Any suggestions?
Thanks,
Vic
Camry093 is offline   Reply With Quote
Old 02-16-2005, 09:38 AM   #2 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Wink
Replace the master switch panel.
Power from the passenger side verifies that the motor and regulator inside the window is functioning properly.
If you do not change the master switch panel and it eventually gets stick, you will risk burning out the motor and/or regulator. Then you will be faced with replacing not only the switch panel, but also the motor and regulator as well.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 02-16-2005, 01:59 PM   #3 (permalink)
View 500KCamry's Photo Gallery
I had the same problem and it turned out to be broken door wiring, within the flexible boot.
The window would lower allthe time, but would not go up unless the door was open. The wiring could fail so that it will go down but not up at all.
I've encountered wiring problems with both rear doors long before I experienced a similiar problem with the front doors.
If you search the "window" threads you will find an explanation about how to splice in new wires.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
