96 camry LE I4 123000 miles on it.
Today, when i was doing my regular oil change, i found there is a liittle ATF fluild (red) at bottom (driver side) of the car. And also, there is some oil burnt at the upper face of catalytic converter, since it's sort of dark and some oil residue on top.
Since it's ATF, there are two sources for it: PS and tranmission case (plus differential case)
I know it's not from PS, so it is definitely leaking from transmission
questions are:
1. is that possible from the rear main seal (which will take alot of time to fix)?
2. possilbe from the axle seal (where drvierside axle plunging into the transmission case)?
3. Or somewhere else?
Anybody can enlighten me?
