Take all the brake fluid out of the master. Use a straw or a turkey baster. Next, wipe the inside of the master clean. Now refill with clean brake fluid. Now bleed all of the brake lines until you see clean fluid coming out of each line. Start with the passenger side rear brake, then move to the driver's side rear brake, then the passenger side front brake and finally the driver's side front brake. Keep topping off the master with fluid and don't let it run dry or you will have to start the procedure all over again.
Mike
