tranny Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2002, 12:08 AM   #1 (permalink)
View Studious's Photo Gallery
I just got my Camry from my grandmother (30k mi) and I plan on soupin it up. But all of a sudden the gears started to slip and the reverse gear is totally gone, its a 1993 le automatic w/ overdrive. I'm told this is a common problem with camry's and it will cost 1400-1800 to fix. Anyone else have this problem?
Studious is offline   Reply With Quote
Old 07-17-2002, 06:48 AM   #2 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
No I have not heard that your problem is a common one with Camrys. It does sound expensive to fix though.
91camryDX is offline   Reply With Quote
Old 07-17-2002, 08:31 AM   #3 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
You need to talk to Phi, our resident tranny expert. But that's pretty low mileage to have your tranny go dead. Most likely your gammy did short trips and probably did not change the fluid often.
The problem with Gen 3 transmissions is that they are very compact in size, so they are more prone to failure. Sounds like your flywheel thingy went dead...but they are pretty expensive to fix.
Silver Streak is offline   Reply With Quote
Old 07-17-2002, 09:09 AM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Check your tranny fluid levels/condition first before running out and getting a rebuild. As Silver mentioned, with that low milage, it's unlikely that the tranny is shot, unless your Granny was rushing home to get the ice cream into the freezer alot :smile:
Phi is offline   Reply With Quote
Old 07-18-2002, 01:53 AM   #5 (permalink)
I think it was the short trips. So far I went to greese monkey and got a full service and a torque flush. The reverse gear is still gone. Thinking about looking for estimates, what else can i do Only 17 in the game and no ride for the summer how weak is that
Old 07-18-2002, 02:04 AM   #6 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
tranny swap!!! heheheh most of us here have done that or u can buy the used tranny from one of the guys here who have a 4cylinder.. u might get it cheap.. jeff??? u wanna sell urs?? i htink i got a customer for ya!! hehehehe.. just a thought..
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 07-18-2002, 02:26 AM   #7 (permalink)
tranny swap huh, what should i swap to?
