Questions on changing valve cover seal and others? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2005, 08:17 AM   #1 (permalink)
View shanzhu1's Photo Gallery
Hi,
When you change the valve cover gasket, you suppose to apply some
RTV sealant to the cylinder head mounts. My questions:
1. Do you need to wait until the RTV sealant to dry a bit before putting
the valve cover, or you must not wait before putting back the cover?
2. Haynes manual mentioned that, for some models of cars, if you disconnect
the battery for too long, the air bag system needs dealers' reset in order
to refunction. Do you have such experience?
Thanks a lot.
-shan
shanzhu1 is offline   Reply With Quote
Old 02-18-2005, 08:18 AM   #2 (permalink)
Forgot: my car is 96" Camry V6.
as said in title.
Old 02-18-2005, 04:16 PM   #3 (permalink)
View jjanari's Photo Gallery
I've also got a 96 cam with the 4 cylinder.
I re-installed the valve cover within a few minutes of putting down a bead of RTV sealant. so far, I've not noticed any leaks.
I've had my battery disconected for weeks at a time and never had the airbag light come on...
jjanari is offline   Reply With Quote
Old 02-20-2005, 04:40 PM   #4 (permalink)
Wink Thanks, I think we should not wait until
it is dry since we do not want the RTV sealant forms a bump through the
gascket path.
So, I think you did correctly.
-shan
Old 02-20-2005, 08:25 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the airbag thig is a new one on me too
Old 02-20-2005, 08:38 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I replaced my valve cover gaskets with brand new ones from Toyota. I cleaned the surfaces completely and didnt use RTV sealant. Works perfectly! A new gasket..if the surfaces a clean and straight, should seal without it. I only need to add some RTV to my cam cap/seal which is slightly weepy.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
