New Oem Antenna Problems
Just yesterday, I tried to install a new antenna for my friend's camry. I purchased a brand off of ebay that appeared to be like the one currently in the camry (2nd gen.). There is a mast height difference that makes the antenna not come through the car - i fixed that (kind of) by putting a longer securing screw into the bottom of the gear box and then filling up the extra space with random nuts to boost up the antenna. The other problem - because the mast is shorter - is that the antenna tries to go up that extra distance, and I hear this aweful noise when it is stuck at the highest point. It goes on for about 4 to 5 seconds and sounds very unprofessional. Is there a way to re-time the system so that it will not try to go up for as long?
