Injen IS Intake Systems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2005, 05:54 PM   #1 (permalink)
View BlackSportivo's Photo Gallery
Australia Injen IS Intake Systems
Hi for all the lads in Australia.
I Have a GEN5 '04 Toyota Camry Sportivo (Black)
and was wondering if anyone out there fitted the IS Intake Systems (Model No: IS2025) to their camrys
http://www.injen.com/new_layout/prod...p1/IS2025P.jpg
Would you guys recommend this cold intake?
how much gain am i expecting if i install this onto my car?
Does it work better than stock filter? at the moment i have stock TRD replacement filter in my stock box.
Black "Knight" Sportivo
BlackSportivo is offline   Reply With Quote
Old 02-20-2005, 06:12 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
thats a short ram not a cold air intake... if its cold (like at night) itll be a bit faster.. if its hot, its going to be just as slow as stock.
itll sound trhoaty louder... erm what else.... miniscule bit better economy.
restrictive stock filter is all a myth. the problem is the standard airbox doesnt flow enough.
terrastrife is offline   Reply With Quote
Old 02-20-2005, 06:42 PM   #3 (permalink)
View NiGHTMaR3's Photo Gallery
who makes a CAI for gen 5 camrys? not ebay ones
2003 Toyota Camry SE V6 Auto - stock...
2002 Toyota Tacomo SR5 4 Cylinder - SOLD!
NiGHTMaR3 is offline   Reply With Quote
Old 02-20-2005, 07:05 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Custom!!
It is sooo simple to make one..you dont need to buy one.
Just use your existing intake hose or use that short intake if you want some flare and extend it which either flexible intake piping or make up some solid stainless steel tubing and run it to the front of the car. Attatch the filter and you've got CAI!!!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 02-20-2005, 07:21 PM   #5 (permalink)
ya know how confusing that sounds? but yes... DIY is the easiest way. just buy some flexible tubing in 3" or so, and snake it to the front of the car... done!
Old 02-20-2005, 10:37 PM   #6 (permalink)
were can i find this flexible tubbing and is there a dyi on it?
Old 02-20-2005, 11:49 PM   #7 (permalink)
back tp my point guys. lets not change my subject.
whats difference btw short ram and cold intake? isnt pretty much same fing?
Old 02-21-2005, 03:20 AM   #8 (permalink)
short ram leaves the intake in the bonnet, sucking up hot heat.. say when ya at the red light.. ya inake soaks all hot under bonnet air so when you take of its like a snail :P cold air gets air from not under the bonnet, and also has a slight ramming effect with the air pressure atthe front of the car being forced into the filter.
Old 02-21-2005, 04:33 AM   #9 (permalink)
so wat cha sayin is that short ram intake is of no use?
Injen did many test on this product didnt they?
would i b wasting my money if i get it or stick wif the TRD stock replacement filter
