spring replacement without removing struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2005, 03:31 AM   #1 (permalink)
View {GodlightSoul}'s Photo Gallery
96 camry
how hard is it to change the springs without changing the stuts (yes, I do my own work, adn I am replacing my stuts today!)
I can't really afford eibach springs right now, but I need to get struts (kyb) immediately because my tires are getting ruined, and I may decide at a later time that I want to put some springs on my car and so I am debating whether I should wait until I can afford it, or be irresponsible and just get them now.
thanks
{GodlightSoul} is offline   Reply With Quote
Old 02-21-2005, 04:17 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
search for other DIY/Howto/FAQ..its exactly the same as doing struts and springs.. but youre putting the old strut back in... also...
that didnt deserve bold... hwo on earth did you not think of the solution?
terrastrife is offline   Reply With Quote
Old 02-21-2005, 10:20 AM   #3 (permalink)
I searched on dial-up for over a half hour , and could not find the answer anywhere
I bold my questions to make them stick out. Always have, always will.
none the less, thanks for the lead.
Old 02-21-2005, 12:50 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
you have the do the same thing wether you change the strut or not... its the same procedure.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 02-21-2005, 01:32 PM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Don't forget it is highly recommended to go for an alignment job any time you drop suspension components. Out of alignment will ruin tires fastest.
Thats why it makes sense to do both at the same time if you have the intention.
Search ebay or this site for springs, I am sure some people here have a spare set lying around collecting dust.
old faithful
amerikim is offline   Reply With Quote
Old 02-22-2005, 12:53 AM   #6 (permalink)
thanks for the replies.
and if anyone finds this thread on their search,
http://vamp.darkravers.net/ has a spring walkthrough (doubles as a strut walkthrough) under his "myDIYs" link.
Old 02-22-2005, 07:35 AM   #7 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
Got my alignment done at Sears for $60. Comes with 6mo warranty. Something to think about.
CDub LXi is offline   Reply With Quote
