Wheel bearing or axle? Which one would cause this.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2005, 07:36 PM   #1 (permalink)
View bennington28's Photo Gallery
I have a 95 camry wagon. The car makes this annoying squeaking sound as my passenger front wheel rotates. I changed the brakes thinking that could be the cause and the sound did not go away. How can you tell if the bearing is bad or if the sound is caused by a bad axle? Are there any "shade tree" tests I can perform?
bennington28 is offline   Reply With Quote
Old 02-21-2005, 08:08 PM   #2 (permalink)
View 500KCamry's Photo Gallery
Bearing.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-21-2005, 08:09 PM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
A bearing noise would be more of a growl or rumbling. With the car up is there any freeplay in that passenger front tire? An axle noise would be a metalic clicking on turns. Did you change the pads and rotors? Make sure the the backing plate isnt touching the rotor.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
