CSF double wide (all metal) radiator. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 02:05 PM   #1 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Talking CSF double wide (all metal) radiator.
Just got my CSF radiator in the mail today. I'll be installing it in an hour or so (after my car's properly cooled down) and I must say, this thing looks very nice!
Came with a lifetime warranty and also has metal endtanks. Now not only will I have a non-leaking radiator, but a much nicer one than I started with.
I'll post some pictures in a couple minutes. While I'm at it, I think I'll post some pictures of some other (currently) uninstalled goodies.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 02-22-2005, 02:30 PM   #2 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
I'll be waitin for those install pics!
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 02-22-2005, 02:45 PM   #3 (permalink)
View MaxHealy's Photo Gallery
From my own personal experience metal tanks are bad. Had a '87 Celica came with plastic tanks OE... wish I'd stuck with them. Metal tanks tend to overheat easier in Toyotas, that's why they stuck plastic ones in there. Why do you think a metal tank costs less than a plastic one? Anywho, I hope it works out, but might want to keep the plastic one handy if it's still in usable shape. If it's not, take it to a local radiator shop and get it repaired, probably 100 if you take the whole car and probably around 70 if you pull it and take just the radiator in.
MaxHealy is offline   Reply With Quote
Old 02-22-2005, 02:51 PM   #4 (permalink)
Zzzz
No point in it, it's a double wide radiator, meaning an extra row of tubing and fins.
here's the pics of the radiator itself:
here's some pics of some other goodies I still have lying in my basement (in need of install time):
-mark
Old 02-22-2005, 04:02 PM   #5 (permalink)
That Geeky Star Wars Girl
ripley's99's Avatar
View ripley's99's Photo Gallery
can't wait to see it on the car mark
what kind of springs are those? are they whiteline?
not to hijack but i got my springs/struts install completed yesterday, i'll have to post a few pics after the car settles some more...i'll chat with ya later.
keri
99 Camry SXV20 5S-FE "Darth Maul" TRD Grocery Getter
89 MR2 AW11 4AG-ZE "R2-D2" Project nearing completion ...
"Darth Vadar" Super Secret Sith Power Project Car
ripley's99 is offline   Reply With Quote
Old 02-22-2005, 04:10 PM   #6 (permalink)
Mr. Toyota
View TadS's Photo Gallery
Couple of questions. How is the weight vs. stock and how much did it cost? Looks like you have alot of installing to do .
(2009 Tacoma, 2000 Corolla, 2000 Camry, 2000 Solara, 1995 Avalon XL, 1994 Celica GT)
TadS is offline   Reply With Quote
Old 02-22-2005, 05:41 PM   #7 (permalink)
Zzzz
almost done, just got the old rad out, the biggest bitch was the temp sensor in the bottom of the radiator, I just cut the clips off, as I have a couple zip-ties that I intend on using for the new radiator in place of them.
The weight is similar, but likely a slight bit heavier. Normally I wouldn't go for 'heavier' but this is an exception.
Give me a couple seconds and I'll post some stock vs double wide pics, as both of them are out of the car right now.
-mark
Old 02-22-2005, 06:18 PM   #8 (permalink)
View 500KCamry's Photo Gallery
CrawlingEye,
Did your old rad break, or did you have problems with it?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-22-2005, 06:24 PM   #9 (permalink)
Zzzz
the plastic end-tank cracked and had a lot of pressure marks. I was leaking coolant which was actually spraying onto my exhaust manifold's heatshield and burning.
not exactly fun when you're driving and all of a sudden you see steam billowing from your hood.
-mark
Old 02-22-2005, 06:25 PM   #10 (permalink)
Zzzz
anyway, almost done, just dropped one of the screws down the hood, time to run to autozone and pickup a new one, figures, the one thing I lose is one of the clamp screws.
-mark
Old 02-22-2005, 08:20 PM   #11 (permalink)
Zzzz
all done, it's installed and running fine. pics coming soon. gotta just upload 'em from the camera.
-mark
Old 02-22-2005, 08:33 PM   #12 (permalink)
Zzzz
Here's the pics:
Double wide vs Stock:
Double Wide installed (engine bay still has some coolant to be cleaned from it though):
-mark
Old 02-22-2005, 09:17 PM   #13 (permalink)
Zzzz
yeah, I know.
if you can see in the picture, I stole a bolt from the heatshield for my clamp, because I went to autozone and tested the bolt and somehow still came out with the wrong pitch threading? said m8-1.25 but I'm guessing it was really m8-1.25 and the coarse bolt just slid in because it was finer threading, but when I went to put the finer threaded bolt in the hole, it was a no-go. I'll return it tomorrow and try the m8-1.25 and see if that works.
either way, when I get a chance, the old manifold's coming off and the rippmods is going in. the leak was really putting a damper on installing that, 'cause I didn't want the coolant to eat at the ceramic coating.
-mark
Old 02-23-2005, 05:08 AM   #14 (permalink)
The Other White Meat
terrastrife's Avatar
double wide eh? looks like a v6 radiator now
how much slack is in the hoses? woudlnt want em to pop off under engine movement
terrastrife is offline   Reply With Quote
Old 02-23-2005, 09:43 AM   #15 (permalink)
Zzzz
no slack, it's OEM fit.
-mark
