Changing From 14 To 15 Inch Wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 04:43 PM   #1 (permalink)
View JIMMYBOY's Photo Gallery
I have a 2000 Camry CE which came from the factory with 14 inch wheels and Dunlop tires. I'd like to change over to 15 inch wheels and Michelin tires. The tires have about 22K miles on them and seem to break belts on a regular basis which results in a wobble at about 24 MPH. Has anyone done this with success and minimal complications? Thanks, Jim
JIMMYBOY is offline   Reply With Quote
Old 02-22-2005, 04:47 PM   #2 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
easy, get the 15's you want and the tires, and have a shop put them on (or do it yourself if you have the tools). Watch out for:
Speedometer may be off a little
Odometer may move a little faster/slower, I don't remember which.
Good luck.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 02-22-2005, 04:49 PM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
you'll be fine unless you increase the total diameter of the tire
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 02-23-2005, 10:20 AM   #4 (permalink)
View dj14901's Photo Gallery
I've done this on my '98 Camry CE, both for winter and summer driving. In the winter it has 205/65/15 Bridgestone Blizzaks on steelies (slightly larger diameter than stock), and in the summer it has 205/60/15 Kumho KH11s on steelies. No issues so far, but I did need to add 5mm spacers to the back to clear the Blizzaks (they're a very wide tire)...
HTH -
DJ
dj14901 is offline   Reply With Quote
Old 02-23-2005, 11:20 AM   #5 (permalink)
tC
View 95camguy's Photo Gallery
here is a link to a tire calculator that you can use so that you overall diameter isnt off(which will throw off your speedometer)
http://www.miata.net/garage/tirecalc.html
... i know its from a miata site but those miata guys arent bad.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
