Double posting is a violation of forum rules.
To reiderate myself, I your engine died and you didn't know it. The only way to loose braking is to loose the vacuum assist. Power steering doesn't go out when the power steering pump is turning.
Unless you fit a cow under your car that waved a magic wand to break the P/S belt/drain the fluid, and drain the brake fluid All at the same time...
Your engine quit.
AIM/Yahoo Toysrme257th
Now with Turbo!
