HOT!!! how can i minimise this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2005, 02:05 AM   #1 (permalink)
Working hard?
View noofa's Photo Gallery
2nd Generation HOT!!! how can i minimise this?
hey
ive noticed since i put my pod filter in for ram air that my car is running hot.... not overheating but hotter than usual- i can feel the heat on my feet when im driving. I have flushed the radiator what else could i do to minimise the heat?
options i have incllude -
1. using 5 inch pipe to make CAI (having trouble finding the time)
2. slipping a couple off washers under the mounts for the bonnet
3. using windscreen sprays on the radiator (my buddie used this on his intercooler)
any other ideas?
can my filter go in fron of the radiator? will it suck water or is it reasonably safe?
Rep'in Team Hamster In OZ
Need power? Get an Ebay Intake mod!!!
***MOD: Signature violation. Size is too big. Keep it under 500x150 pixels.***
noofa is offline   Reply With Quote
Old 02-23-2005, 02:59 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
5" pipe is overkill for a CAI. 2.5" - 3" is good.
I would stick the filter inside the fender.
"Skoolin' the unlearned!"
Old 02-23-2005, 03:18 AM   #3 (permalink)
Working hard?
the filter is 5 inch as is the connection i bought from redline performance. so i figure its easier.
is it worth lifting the back of the bonet?
Old 02-23-2005, 04:38 AM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
When ya lift the back of the bonnet...can't u just remove the rubber seal that goes there instead of using washers to lift it off the seal? That would create an air-gap and not make the bonnet out of line with the fenders.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 02-23-2005, 04:45 AM   #5 (permalink)
Working hard?
yeh apparenly you can, best to ride with your windows down though, apparently engine fumes get in the cab. i think you can jack it up a little without wrecking the looks check the link below
http://www.toyotanation.com/forum/t53263.html -- part of the free mod series by toysrme (i think thats his name)
Old 02-23-2005, 04:51 AM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
I did it more than a year ago.
No rust in my engine bay, no fumes in the car... Admittantly I have pair of air filters. On my cabin (blower) and in the air flilter slot for outside air so... Not like I'd smell it anyways.
Shimming the hood with 2 washers is fine. As much tighter as this ES panels are to anything, not an LS 400 I've ever seen, it actually looked better when I added a pair of washers to jack it up a tiny bit.
Now if I just wouldn't have let the hood drop on a tool and warp it a few months back!!!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-23-2005, 05:06 AM   #7 (permalink)
Working hard?
without those filters and shit, how could i prevent the gas from getting in?
think ill chuck a couple of washers under the hood so its not as drastic as removing the seal.
also would changing the front grill thing max out the airflow? or is it so small that it dont matter?
where does everyone think i should put the air filter????
Old 02-23-2005, 06:25 AM   #8 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Err, have you checked your plugs lately? Sounds like you are running way lean. Prime sign is overheating. You should check before you have a one piece engine.
old faithful
amerikim is offline   Reply With Quote
Old 02-23-2005, 06:36 AM   #9 (permalink)
Ultima's Avatar
View Ultima's Photo Gallery
i put a pod in my car (cen 2), so did my mate and neither of us has noticed hotter running temperatures. so get your plugs checked as amerikim suggested. i'll be putting a cai soon enuff (dodgy backyard job). mite give the washers a try though.
anyone care to post a pic of where we r to add these washers?
y be like dat for?
Ultima is offline   Reply With Quote
Old 02-23-2005, 09:54 AM   #10 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
removing the seal sounds like a good idea. maybe I'll try it soon. I don't think the fumes will be much of an issue, as your exhaust itself generally doesn't produce any fumes in the direction of the engine-bay.
if you have any funky smells, you likely have a leak to begin with.
further more, if you notice, you can recirculate air within the car or get fresh air from the outside. if you're nervous of this, just have it recirculate air.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 02-23-2005, 11:25 AM   #11 (permalink)
tC
View 95camguy's Photo Gallery
yeah i agree with the others in that it sounds like you got another problem going on. but after you figure it out throw some redline waterwetter in the radiator to bring the temps down a bit. supra guys love this stuff!!!
*** disclaimer: ive never used it
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 02-24-2005, 02:22 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Originally Posted by Ultima
mite give the washers a try though. anyone care to post a pic of where we r to add these washers?
The washers go in between the hood and hood mounts.
Its self explanatory once you see the hood mounts.
Old 02-24-2005, 02:24 AM   #13 (permalink)
Working hard?
ill report back on the weekend after i have changed oil, spark plugs and raised the bonnet.
Old 02-25-2005, 01:32 AM   #14 (permalink)
Working hard?
fuck 88le your right 5 inch is big i meant 3!
schooled again
Old 02-25-2005, 01:56 AM   #15 (permalink)
Toysrme's Avatar
Cool
You have slots for the filters. That and the fumes would not get in. (there are no fumes... It *should* be a sealed engine ) You shouldn't be able to detect any oder when you open the hood.
The majority of the airflow in a Camry (IDK which model) is designed to enter the nose, and be expelled at the BOTTOM REAR of the engine bay. The vast majority will exit there when the car is in motion.
Now with Turbo!
