Cheap clutch pedal assembly... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 01:27 AM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Ok, before the flames, I have searched for hours now, I need to find a clutch pedal assembly doesnt matter if used for my 97 camry. I am beginning to put parts together for my 3SGTE swap along with the MR2 e153 tranny. I have located the punch out marks and drilled accordingly. I now need the clutch pedal and a new master cylinder and reservoir. I can find the master cylinder but no reservoir. And no one seems to have the pedal assembly. Where should I look?
97camryman is offline   Reply With Quote
Old 02-24-2005, 07:56 PM   #2 (permalink)
97camryman's Avatar
Anyone?
Old 02-24-2005, 07:58 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
wreckers.
terrastrife is offline   Reply With Quote
Old 02-24-2005, 09:08 PM   #4 (permalink)
97camryman's Avatar
Cant seem to find any local jumkyards with any manual 4th gen camrys.
Old 02-24-2005, 09:12 PM   #5 (permalink)
限界域への独走。
View mobes's Photo Gallery
3rd gen is the same too. The only difference is the cruise switch.
mobes is offline   Reply With Quote
Old 02-24-2005, 10:20 PM   #6 (permalink)
97camryman's Avatar
Really? That would help a lot, 2 generations to pull from= better than 1.
Old 02-24-2005, 10:22 PM   #7 (permalink)
限界域への独走。
Yep. I used gen4 pedals, shifter, and tranny in my car.
Old 02-24-2005, 10:28 PM   #8 (permalink)
限界域への独走。
BTW I have a shifter assembly for sale. If you're interested, send me a PM. Link below.
http://www.toyotanation.com/forum/t46184.html
Old 02-24-2005, 10:42 PM   #9 (permalink)
97camryman's Avatar
This shifter and cable set will also work with an E153 transmission? I am new to toyota transmissions so please bear with me, will any shifter i4 or v6 are they all the same? Will this i4 shifter work with the v6 manual tranny as well as the i4 or are cables and shifters different?
Old 02-24-2005, 10:45 PM   #10 (permalink)
限界域への独走。
See the 4th post in the linked thread. There is a difference in the thickness of the brackets, which can be made up for with shims.
Old 02-24-2005, 10:51 PM   #11 (permalink)
97camryman's Avatar
But thats it right? If so my offer stands in the PM I sent you. I also need a clutch pedal assembly if anyone has one.
