Exhaust questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 12:52 PM   #1 (permalink)
View mmurray70's Photo Gallery
Exhaust questions
I had to get a flex pipe installed on my 93 4cyl this past weekend. While the car was on the lift I had a good look at the rest of the exhaust and it all seemed pretty good except for both of the cat joints. I decided to just have a piece of pipe installed there and get rid of it. I know by doing this the car will be a tiny bit louder, but It ended up being alot louder then I expected. Its kinda annoying. It idles extreamly quiet and in the higher rpms its fairly quiet too, but around 2000 rpms it makes an anoyying sound and you can even feel some vibration.
Is this to be expected by removing the cat or do I still have another leak in the front of the system somewhere? Most of the sound/vibration seems to be comming from the front of the vehicle. I'm wondering about the resonator, but I dont wanna cut that out too and just have it louder again. Any advice?
mmurray70 is offline   Reply With Quote
Old 02-24-2005, 01:28 PM   #2 (permalink)
View 500KCamry's Photo Gallery
Ususally exhaust problems are with the flexible pipe, that bit covered with a SS braid. The pipe underneath the braid breaks first. Then the braid deteriorates. Ususally the pipe from the manifold to the exhaust system is one piece and includes the cat, it is expensive, but the genuine toyota part lasts a long time.
Most places it is against the law to remove the CAT.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-24-2005, 06:15 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
did you replace the cat with a mild steel peice? thats a no no, if ya gonna replace the cat make sure its THICK stainless mild steel drones inside the cabin
why were you getting a flex joint for?
terrastrife is offline   Reply With Quote
Old 02-24-2005, 07:25 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
In most places running without cats will also cause you to fail visual inspections (for emissions) in most places.
Old 02-24-2005, 07:58 PM   #5 (permalink)
yeah no cat = big big fine in australia.
Old 02-24-2005, 08:39 PM   #6 (permalink)
View Beaver's Photo Gallery
I usually just gut my cat. It looks good, flows good and sounds good.
'02 Sienna CE 219,000km and rising.
'98 Corolla CE 295,000km and rising.
Beaver is offline   Reply With Quote
Old 02-24-2005, 10:12 PM   #7 (permalink)
View wildfire's Photo Gallery
I had to get flex pipe on mine when I changed my muffler. A stock camry muffler (mine anyways) feeds in from the side. Just about every after market muffler I've seen feeds in from the rear. That's why I had to get a flex pipe...I don't know what the case was with mmurray70 though...
wildfire is offline   Reply With Quote
Old 02-25-2005, 12:59 AM   #8 (permalink)
sure you dont mean a bit of bent pipe?
Old 02-25-2005, 01:18 AM   #9 (permalink)
限界域への独走。
View mobes's Photo Gallery
Back on topic: I don't know if that much mild steel pipe would cause that bad of resonance in the cabin. Mine sure has alot though since switching to a full mild steel system.
mobes is offline   Reply With Quote
Old 02-25-2005, 07:07 AM   #10 (permalink)
mild steel drones in cabin heaps... i have nfi why im not s scientist.. mild and stainless are like very similar but meh.... my exhasut is mild steel, but my resonator and muffler are matched.. so the muffler kills the sound left from teh resonator... if you get a magnaflow muffler, get a magnaflow cat too.
Old 03-01-2005, 02:39 PM   #11 (permalink)
Its just mild steel but I really cant see that being a problem. Stainless is almost never used at any of the muffler shops around here. And it is bent a little to clear part of the frame. Sorry about that.
The piece is welded at the flex and flared/clamped to the rest of the system in the back. Do you think it would be because of clamp? Its real bad around 1800 rpm. If your heading slighly downhill on a highway and it hangs at that rpm its real bad. Fairly loud deep sound and you can even feel a slight vibration in the floor.
I'm not worried about fines, not a concern in my area. And the noise on acceleration can be lived with i guess. Just like to get rid of this vibration if possible. Any other advice?
Old 03-02-2005, 06:48 PM   #12 (permalink)
Old 03-02-2005, 09:19 PM   #13 (permalink)
its just droning from bad design. quite simple.
Old 03-03-2005, 12:25 AM   #14 (permalink)
Wouldn't hurt to check for holes or leaks around the clamp.
Old 03-03-2005, 01:47 PM   #15 (permalink)
What exactly is droning? And if its such a bad design, what do you suggest I change?
