changing spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 02:14 PM   #1 (permalink)
View oldgoalie's Photo Gallery
My first post...I have a 2002 Camry LE (4 cyl) with 95,000 miles. I want to change the spark plugs but can't even see them! I'm assuming they're at the back of the engine and I'll have to remove the plastic valve cover to get to them. How difficult a job is this? Should I just let the dealer do it (at over $100 for changing 4 spark plugs!)? Thanks for any info.
oldgoalie is offline   Reply With Quote
Old 02-24-2005, 02:22 PM   #2 (permalink)
View 500KCamry's Photo Gallery
DIY, buy new plugs, use them to get 3/8 drive socket, 6-8" extension and a ratchet. Pull the plug wires and replace.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 02-24-2005, 02:30 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
^ what he said....
unless you have a v6 where it's a bitch and a half to get to the sparkplugs in hte back of the engine under the intake plenum, you have no excuse to not to them yourself
those cheap spark-plug changing kits with the ratchet and extensions actually help a lot...
HaHa
Old 02-24-2005, 02:31 PM   #4 (permalink)
I guess I should have been more specific...where are the plugs and how do I get to them?
Old 02-24-2005, 02:34 PM   #5 (permalink)
TN Pussy Man
haha....okay, I see.....
they should be under the plastic engine cover
HaHa
Old 02-24-2005, 02:37 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Anyone got a pic of this "plastic engine cover". Every 5SFE i've seen has the 4 wires right there on top of the valve cover. I Must be missing something!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 02-24-2005, 02:54 PM   #7 (permalink)
That's what I'm thinking, maybe he has a V6?
01 XLE V6 310K km
Old 02-24-2005, 05:04 PM   #8 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Those wires that go into the valve cover goes to the spark plugs. Pop those out and then use the socket wrech with an 8" adapter to unscrew the spark plugs.
RedPhoenix is offline   Reply With Quote
Old 02-24-2005, 05:42 PM   #9 (permalink)
View EggBeater59's Photo Gallery
95k on a 3 year old car? someone's been doing alot of driving! when you replace them, make sure to not cross thread the plugs, and put some anti seize greese on. it isn't much fun when you have to struggle forever cause they're stuck.
1990 st-185
EggBeater59 is offline   Reply With Quote
Old 02-24-2005, 06:11 PM   #10 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
owner's manual (under maintenance) or haynes manual will help alot
WhiteRabbit is offline   Reply With Quote
Old 02-24-2005, 09:20 PM   #11 (permalink)
VeeZed
No shit shirlock..i wasnt doubting the sparkplugs and the leads..just the cover that goes over them. Much like the 3VZ and 1MZ..which have plastic covers over the entre thing to neaten it all up. I didnt think the 5SFE had a cover like that, I thought it would be like the 3SFE.
Old 02-25-2005, 10:50 AM   #12 (permalink)
Guys,
My car is a 4 cyl. The plastic cover on the top of the engine has V V T- I on the top. I just checked again and it appears that the plugs may be under this plastic cover. There are 2 rubber grommets and 2 hex nuts holding the cover on. Guess I remove those to remove the cover. Yep, I drive around 2,500 miles a month. Thanks to all for the input. By the way, my owner's manual doesn't help much.
Old 02-25-2005, 11:29 AM   #13 (permalink)
Originally Posted by oldgoalie
Guys,
It's a DIY job, you should find it easy.
Re: plugs - most people in this forum recommend staying with platinum NGK's. I've tried Bosch and didn't find them good, so I'll go back to the recommended.
See you drive as much as me
01 XLE V6 310K km
Old 02-25-2005, 12:23 PM   #14 (permalink)
View jimmykce1's Photo Gallery
I would suggest looking at Iridium sparkplugs which should increase your preformance and gas mileage.
jimmykce1 is offline   Reply With Quote
Old 02-25-2005, 12:39 PM   #15 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
he has a 2azfe, and not a 5sfe. 2002 is when camry platfom started using the 2.4 and not the 2.2s(5sfe). I hope this solves your questions...
oldgoalie - get a haynes manual; get denso-platinum's and genuine totoya wires. Looks like your not into modding cars too much, the above mentioned list should do suffice for you, you don't need to go aftermarket wires (magcore, etc) if you don't really want to. But whatever you do, DONT GET BOSH plugs. They decrease our mpg's. You don't need iridium plugs, as your not a v6 and looks like you don't have plans for modding.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
