You've likely got a wiring break in one of the doors. Replace the fuse, then jump in with all the doors closed and find out which control (window up/down, power lock, etc.) pops the fuse. The break/short may not show up with the doors open because of the flex in the wiring. It's likely a rear door wiring problem, they break first.
If you have a moonroof and power seats, they'd stop working too.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
Reason: Fix text
