camry overheating problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2005, 01:29 PM   #1 (permalink)
View glad76's Photo Gallery
Hey guys
this winter has been nothing but badluck for my camry. Here goes. The radiator has a hairline crack at the top of it so me and my dad replaced it. We refilled it with coolant and took the airlocks out to the best of our ability. We took it for a test drive and the car still overheated. We looked at the cooling system and saw that the overflow tank was full. We removed some of the coolant from the tank and let the car run for a bit and found the same thing that the overflow tank gets full. Also the heating inside the car is not hot any more. From a few ppl i've asked they think the head might be warped/cracked or the heater core is clogged. The smoke coming out the car is white and there is something dripping from the exhaust which looks like water. Let me know of any idea's or suggestions.
Thanks
glad76 is offline   Reply With Quote
Old 02-25-2005, 01:44 PM   #2 (permalink)
View Beaver's Photo Gallery
Blown head gasket would be my first guess. What engine do you have? I've got a 3vzfe with a blown HG it runs fine but makes a lot of steam out the tail pipe. When run hard it overheats. The block empties of coolant and does not refill from the rad because the rad fills the block off the top and once it gets down a little no more coolant from the rad to the block. I'm checking my coolant daily until I get a new motor dropped in (soon, very soon).
I'd be carefull if I were you not to overheat your engine too much (or at all) if all you have is a blown gasket it is cheaper to fix than a cracked head.
If oyu go to a "stealership" to have them look at it or fix it they will charge large for the gasket set. You can get them outof the states for about 1/6th the price (for the 3vzfe set anyways).
'02 Sienna CE 219,000km and rising.
'98 Corolla CE 295,000km and rising.
Beaver is offline   Reply With Quote
Old 02-25-2005, 01:47 PM   #3 (permalink)
engine is a 5sfe. Yeah i've looked into a few places if thats the case. I haven't been driving it since it happened it's been sitting in my garage i was planning on fixing it once the weather gets warmer
Old 02-25-2005, 01:51 PM   #4 (permalink)
Good idea not to drive it if you plan on fixing it. You don't want to get coolant in your oil. If you do chances are you will need to rebuild the entire engine cause the coolant can fuck your bearings.
Old 02-25-2005, 07:34 PM   #5 (permalink)
rusty9's Avatar
Gameroom cash: $442005
View rusty9's Photo Gallery
if you have no heat inside...and car get overheat...sounds like thermostat, which you should have replaced when you did the radiator. $10 more for a lot less headaches.
P.S. water is normal in the exhaust. if the smoke is blueish/white that most likely means its burning a bit of oil.
rusty9 is offline   Reply With Quote
Old 02-25-2005, 09:08 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Ditto - thermostat
But if you havn't blown the head gaskets all ready, I gaurentee you will if you keep driving it like it is.
Whenever you replace the thermostat, drain the radiator, drain the block itself, and flush the entire system.(hose pipe and finish with some coolant system cleaner)
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-26-2005, 12:05 PM   #7 (permalink)
the thermostat was replaced as well when the rad was replaced so i think it's that. i also tested the thermostat before i put it in the car.
