30mm socket for wheel lock nut, need to be special?
Hi,
I am thinking of changing CV boots for my 96 Camry V6.
I was about to buy a normal 30mm socket with chrome on it.
It is 12 pt (instead of 6 pt) and measured 1 inch deep of the
socket opening.
My questions:
1. This this kind of socket too weak and too shallow?
Do I need to use a specialized socket for it?
2. If I use a racket (1/2" drive, pretty good, but not
a breaker) with a pipe as an extension, will that break
the rachet for unscrewing the lock nut?
socket opening.
My questions:
Thanks,
The socket might not be deep enough. Take it out of the store and test how deep it goes on.
I use a 1/2 drive 2' handle, not a ratchet, with a short pipe for an extension, then just stand on the end of the pipe. The same probably won't break your ratchet, but the 1/2" handle is designed for the stress.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
Reason: Fix text
You should get a specialized wheel nut socket. Pep boys has them for about $10-15. They are 6 points. You risk rounding off your wheel nut with a 12 point. If you have a decent 1/2" drive rachet you can use a pipe, but I wouldn't give it more than 125-150 ft/lbs of force. You may want to pick up a basic 1/2" breaker bar so you don't screw up the rachet.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
If it's 6 point, there's a special tool most parts stores have that is basically a 30mm impact deep socket. If it's 12 point, that won't work... so just get a regular 30mm 12 point socket, that's what I used on a '98 Corolla the other day and it worked fine.
