How to check ATF Level? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2005, 05:55 AM   #1 (permalink)
asm
View asm's Photo Gallery
I am trying to figuer out the proper way to check the ATF level.
I notice that there are 2 rang on the stick. Hot and Cold. I am assuming cold is for when the car is sit over night and not running. How is when the car has been driven for 20 min. and not running?
Please Correct me if I am wrong.
aSM
asm is offline   Reply With Quote
Old 02-27-2005, 07:46 AM   #2 (permalink)
tC
View 95camguy's Photo Gallery
you need to ckeck it with the motor running
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 02-27-2005, 10:39 AM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
aSM
Fully warmed up, on a level surface, in "Park", the ATF should be just about at the HOT mark.
DFBonnett is offline   Reply With Quote
Old 02-27-2005, 10:59 AM   #4 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
You can stir the gears by moving from D to R etc, before taking a read. I just check after a 15 minute drive on nice flat surface with engine running and fully warmed up. It should not go past the Hot mark,, drain some if it does. Do not overfill.
You can drain easily through the dipstick's hole. Make sure engine is off when you do this.
old faithful
amerikim is offline   Reply With Quote
Old 02-27-2005, 03:06 PM   #5 (permalink)
asm
You mean "drain easily through the drain hole," right?
aSM
Old 02-28-2005, 02:47 AM   #6 (permalink)
View HeNry2kOoL's Photo Gallery
aSM
I believe there's a hand pump you can buy that has a clear hose that you stick into the dipstick hole to pump fluid out.
HeNry2kOoL is offline   Reply With Quote
Old 02-28-2005, 06:48 AM   #7 (permalink)
amerikim's Avatar
HeNry2kOol got it, $4.75 from car stores. I also use it for draining fluid resevoirs. Works like a soap dispenser pump.
It's much easier to adjust fluid level by just getting small amounts out through the dipstick's hole than going underneath and using the drain.
old faithful
Old 02-28-2005, 10:38 AM   #8 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
For those of you guys who flush the Trannies, I can oly drain 2 Quarts, so I was told to crank the engine to get 1 more quart out of the torque converter. This true? How safe is this. This is my mechanic who told me. Somewhere here, when flushing, do 3 times, 2 quarts at a time, every 20 miles and you would have flushed out the old ATF.
Suggestions welcome. Using good Tranny fluid is key to a long and useful transmission.
mandyfig is offline   Reply With Quote
Old 02-28-2005, 11:10 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
What your doing is a drain and fill, not a flush.
You'll never be able to drain the fluid completely as theres fluid left in the torque converter.
Well the new fluid is going to mix with the old fluid.
The sure way to get all the old fluid out is to do a flush. For this you need to take the car to a shop that has a tranny flush machine.
"Skoolin' the unlearned!"
Old 03-01-2005, 03:31 PM   #10 (permalink)
mandyfig's Avatar
Tranny Flush machine....that's new....never heard of it....
