I'm gonna blow up the camry!! help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2005, 08:36 PM   #1 (permalink)
View turbo sol's Photo Gallery
Angry I'm gonna blow up the camry!! help!!
well where do i start.
i was doing an engine swap to replace an old tired 98 camry 4 cyl. auto.
engine in swap went good. car starts and run fine.
the transmission does not work!!!! ( it worked fine before hand)
i can shift through the gears (automatic) and unless i am in park it acts like it is in nuetral. no power to the wheels. What am I missing here? any help would be great.
the fluid level is good and the axles move freely. I can push the car both forwards and backwards. no check engine lights either. I am stumped and out of solutions.
help?
turbo sol is offline   Reply With Quote
Old 02-27-2005, 09:27 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Use plastic, a block 4 and some decord will shred the thing good.
But thats just advice from an ex-combat engineer.
old faithful
amerikim is offline   Reply With Quote
Old 02-27-2005, 09:53 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
can the car be pushed in park?
Old 02-27-2005, 10:49 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
did you mate the flywheel and the tranny properly?
because if you haven't touched the tranny, then I wouldn't think anything would happen to your torqueconverter or clutch or what not
HaHa
Old 02-27-2005, 11:39 PM   #5 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
you may have missed an electrical connector or two, or you put the shifter cable on wrong, ex..too loose or too tight.
when you say it acts like its in neutral, unless you are in part, please explain.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 02-28-2005, 02:55 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Make sure the torque converter is installed properly. It should seat fully onto the input shaft of the tranny.
My friend fried a tranny because of this, so make sure the torque converter is seated all the way on the input shaft.
The torque converter drives the pump within the tranny. Pump not being driven = no fluid = fried tranny.
"Skoolin' the unlearned!"
Old 02-28-2005, 08:41 AM   #7 (permalink)
when i wasy saying it acted like it was in nuetral, when not it park I meant that i can put it in any gear and push the car with not resistance.
I think that it has to have something to do with the torque convertor/tranny I am confused because everythgin is bolted up with no gaps. you would think that it would be fully seated if that was the case.
does anyone have a pic of the gear selector cable installed? that way i can make sure mine is correctly oriented.
Old 02-28-2005, 10:02 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
The lever on the front of the neutral safety switch should be in the left most position.
If you unbolt the cable and move the lever manually, you should feel some resistance before it clicks into the left most position. Whereas it'll move easier between the other positions.
Anyways you want the lever in the left most position, then bolt up the cable. The bolt up point for the cable should be about in the middle of the slot on the lever.
After you get the cable bolted up, make sure you can move the shifter from P to L and from L back to P.
Old 02-28-2005, 10:57 AM   #9 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Did you do the swap youself and how was it?
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 02-28-2005, 01:03 PM   #10 (permalink)
it the left most position when you are looking at it park?
and jhbhatia, the swap wasn't bad. lots of plugs, and the axles are a PITA. I say take your time and be organized. This isn't my first swap (firrst camry swap, but I have done honda's before) the basics are all the same.
Old 02-28-2005, 01:35 PM   #11 (permalink)
is there a special way the torque convertor needs to be indexed? (as compared to the flex plate?)
and is there a special way to fill the torque convertor?
thanks guys.
Old 02-28-2005, 01:39 PM   #12 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
you know..that is one thing that this site has more than any other. Moderators and Members who really know their stuff. Bum about the engine swap. The answer will be posted on this thread
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 02-28-2005, 09:05 PM   #13 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I want to move next to you 88LE. You have all the damn answers!
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 02-28-2005, 09:10 PM   #14 (permalink)
The Greatest
View CamNub's Photo Gallery
Sure....Thats why you want to move by him.
But did i miss something?
What swap did he do?
CamNub is offline   Reply With Quote
Old 02-28-2005, 10:19 PM   #15 (permalink)
all i did was take out the 4 cyl in there that was about to die, and switch it with the same engine. nothing for performance, just trying to sell the car when its all done. Its not my car, but its been in my garage for almost a month now. I just want it out!!! I will post some more pics tommorrow.
